RE: Tmaxx basher
Sounds fun. So these A-Arms I have are stuck in the old bulkheads.... I bought them used knowing that the bulkheads were bent, and 2 of the front upper arms are stuck in the damaged bulkhead. The arms are perfectly fine and not bent but the bulkhead is bent to **** which in turn bent the pins that hold the arms in the bulkhead. I only have a dremel to work with for now, so I have to cut the old bulkheads to remove the bent pins and use the arms. Has this ever happened to anyone else here?
