RCU Forums - View Single Post - 50cc Break In Questions-
Old 10-25-2010 | 02:38 PM
mrbigg's Avatar
mrbigg
My Feedback: (21)
Default RE: 50cc Break In Questions-
ORIGINAL: captinjohn
My 2 cents....have the oil ratio a little rich...not the hi-speed needle. It is your choise also on cowl. Having it off you can check the bolts on everthing easy, and when satisfied,...place cowl on. It is good to re-check mounting bolts ect after the first couple of flights. Always have a line from pump cover into dead air in fuse. Capt,n
That's how I roll, the same as the Capn'!
I like to check the bolts after each flight for the first several. Plus if it's a new plane and you smoke it into the ground on the maiden, you could always sell somebody the NIB cowl.
