RCU Forums - View Single Post - Priming Engine - "Blocking Exhaust Method"
Old 10-26-2010 | 12:51 PM
rchobbyunlimited's Avatar
rchobbyunlimited
Default RE: Priming Engine -
That method works on the redcats as well thats how I used to prime all the redcat engines untill I started using fuel fiters with primer pumps on them. check to make sure that the muffler is on tight and that the silcone coupling is tight on both ends. But yes it should suck up the fuel very well with this method.
