RCU Forums - View Single Post - converting a .21 nitro to spark ignition
Old 10-26-2010 | 01:58 PM
  #33
Nikolas K
Default RE: converting a .21 nitro to spark ignition
ORIGINAL: sam123
Well thanks for all the help guys.
So it looks like I will be using two battery packs then. And to make things easier I will get it running on glow fuel first. Gotcha
I still have a few litres of glow fuel left over anyway. Better use it before it goes stale [:@]
Just to let you know, I will be buying the parts for it this weekend. I can't wait to start working on this
Bear in mind, that using glow fuel might dictate alteration of the static ignition advance (ie the angle you set the spark when you turn by hand). When using gasoline, this angle is usually 28-30 degrees Before TDC.I do not know how much it should be when trying glow fuel, which has different flame propagation speeds. The guys who are trying spark ignition with glow fuel may help you.
