RCU Forums - View Single Post - Turnigy Nano-Tech batts?
Old 10-26-2010 | 03:43 PM
Velco's Avatar
Velco
Default RE: Turnigy Nano-Tech batts?
Sorry to say but I think that 5000mAh is absolutely needed in windy conditions because the batteries should not be discharged more than 80% of their nominal capacity, for many different reasons.</p>
Also, increasing the C rate and taking lower capacity at the end of the day will give very similar result. Batteries with higher C rating give more Volts but are also more heavy for the same nominal capacity.</p>
