RE: T-28 Dave Platt
As with the wing, I like to lay out most of the major components that will be inside the fus.prior to construction. As a general rule, I want to be ableto remove any major componants for repair or replacement. Once the air tank is positioned in the fus as shown on the plans, it is impossible to remove. Therefore, I made modification to F7 thru F9 so that I would be able to remove the air tank. Also, I want to be able to remove the pushrods so will make accomodations to allow me to do this as well. I hope the pics are self explanatory.
