ORIGINAL: Moontan13
My question is. Even though I had thread locked the set screws in the feathering shaft the previous day, they still did not hold. Any ideas or thoughts on this please! Could have it been the plastic links to the balls on the grips?
Sorry to rant on a bit guys! Thanks in advance for any help greatly appreciated.
Terry
That may have been due to residual lubricant in the threads. I was going to run all the metal parts from my kit through an ultrsonic cleaner to degrease them.
Thanks Moontan13,
I should have remembered that, it happened to a new Pinion gear I fitted after I had lubed the motor bearing on th B400 some time back. I suppose the memory begins to fade once you get past 65. LOL. Thanks for the reminder!
Terry
