<span id="result_box" lang="en"><span title="" se="Yes de eerste hevels zitten erin, nog niet gelijmt dat komt later" te="Yes the first levers are in it, yet gelijmt that later" closure_uid_jnstlo="60">Yes the first levers are in it, yetglued, that later.</span><span title="" se="Midden stand, het scharnierpunt van de hevel heb ik precies op het scharnierpunt vd Aileron gekregen" te="Middle position, the pivot of the lever, I have exactly the hinge got vd Aileron" closure_uid_jnstlo="61" style="background-color: #e6ecf9; color: #000">
</span></span>
The middle position, the pivot of the lever , I have excactly the hinge got vd Aileron
Max right is 45mm
Max left is 60mm
<span id="result_box" lang="en" class="short_text"><span title="" se="het bouwen gaat goed alleen de reacties hier zijn minimaal" te="building is only good comments here are minimal" closure_uid_jnstlo="127" style="background-color: #e6ecf9; color: #000">
The building is going good bath the comments here are minimal
Look at
www.jetforum.nl
Thanks and regards
Japiooooo</span></span>
