RE: engine servo
If you use the cable you may want to put a little solder on the ends of the cable. Use flux on the cable and just enough solder to harden up thearea were the set screw will be pressing on the cable. This will keep it from unravelling (sp?) when you tighten up the set screw with the EZ connectors.
