RE: KMP Stuka-build details
Here are some pics of todays progress. Ignition module mounted to the underside of the hatch lid I cut out from the top of the fuse behind the firewall. Also shown is the patched up lower fuse which was cut away to make clearance for the Evolution inverted Pitts style muffler. Inside the fuse you can see some of the 11 ply blocks with blind nuts which attach the cowling securely.
