RCU Forums - View Single Post - Redwing 50cc Sboch
Old 10-28-2010 | 06:02 PM
  #66
Tseres's Avatar
Tseres
Default RE: Redwing 50cc Sboch
Second installment was fitting the cowl. That took some doing. Me engine needs 2 1/2" Standoffs on this plane. If I did that Id have to cut some more clearance for the muffler and the back of the carb. As of now I have a 1/4" gap between the cowl and the back of the spinner. I much prefer that the factory move the firewall back and let me shim the Standoffs forward. Ill work on the clearances some more so all I have to do is change standoffs when the time comes. I'm going to leave it the way it is for now. I don't know how the DLE fits but a D/A would have the same issues that the YD-A has. I had to cut a lot of the cowl out to make things fit. When I put the plane on the ground you couldn't hardly tell the difference.
ID:	1524531   Click image for larger version
ID:	1524532   Click image for larger version
ID:	1524533   Click image for larger version
ID:	1524534   Click image for larger version
ID:	1524535   Click image for larger version
