RE: Relabeled Area 51
I figured out a couple weeks ago that I m a good engine designer also.
Took a Area 51 case and installed a some DLE clone crank, piston and cylinder to it, With a little modification it worked great.
Has to be one of the smoothest running engines I have ever seen but the squash is off about 1mm and the power is down about 8%
Need to mill off about 1mm from the cylinder or the case but not worth the cost.
Was just trying to figure out what to do with these cases I have no parts for
Milton
