RE: Lexan Body Stitching
When I cut out a clear body shell I save all the trimming. When you get a crack you use the Lexan trimming as backing and use the Shoe Goo adhesive so you end up with a very strong repair no matter how big the crack is. Since the trimmings have different shapes and profiles you can usually come up with a backing peice that has a profile or curves that matches the cracked part of the body close-enough. I also use trimmings to re-enforce the holes for the body posts.
