RE: EQ6 Ign Question
Ok tell me what I'm doing wrong. I assigned the Ign cut off to channel 5 by turning the function switch to #2 and rotated the channel switch to channel 5. Held down incr and decr and turned on power to the EQ6. The led at channel 5 started to blink. At that point I turned off the EQ6 and set the switches back to 0. I set my radio to use the gear switch which is channel 5. The radio is acknowledging the switch because it has an led that goes on and off in the programming when the switch is operated for channel 5. The Green led on the EQ6 does not light. I only get a blip of light on the red outside led when the EQ6 is powered up. I am assuming the EQ6 does this internally because there is nothing plugged into the output of the EQ6 on channel 5. Can you help?
