HK 600 clone
<p style="margin-bottom: 0in">Hello All</p><p style="margin-bottom: 0in">I have a few questions!</p><p style="margin-bottom: 0in">This is what I have.</p><p style="margin-bottom: 0in">HK 600 clone</p><p style="margin-bottom: 0in">Replace the main & auto rotation gear also tail drive gear and fly-bar cage.</p><p style="margin-bottom: 0in">I am running a 2<sup>nd</sup> battery pack with a BEC for the servos</p><p style="margin-bottom: 0in">I am going to test it out with a 6s 3300 ma (hover only)</p><p style="margin-bottom: 0in">Motor is Raiden T20A 1700 KV from Xheli</p><p style="margin-bottom: 0in">11 tooth pinion (not sure on the head speed yet)</p><p style="margin-bottom: 0in">ESC Hobby Wing 100 amp platinum pro</p><p style="margin-bottom: 0in">Servos (3) Hitec HS-422 (4.8 / 6 volt)</p><p style="margin-bottom: 0in">Tail servo now is a EXI D122F (6 volt)</p><p style="margin-bottom: 0in">Gyro Detrum GY48V Hobby Parts</p><p style="margin-bottom: 0in">BEC Turnigy 5-7.5A (running 6 volt) all servos</p><p style="margin-bottom: 0in">Good Bad No Comment</p><p style="margin-bottom: 0in">Also only going to sport fly!</p><p style="margin-bottom: 0in">Feed back WELCOME
Thanks RCREDHOTS</p>
