RCU Forums - View Single Post - Flying Sitting Down ?
Old 11-01-2010 | 03:10 PM
  #40
aronph
Default RE: Flying Sitting Down ?
why isnt there a manufacturer making a  "flight chair"?-it would have rudder pedals and a yoke or stick with gear, flap and mix switches on the yoke,and a throttle lever,kinda like the scale flight simulator contols you can get to plug into your computer and the inputs would run to a 2.4 Tx-made from a wheelchair, but since you would be using your feet for the rudders like scale, you would have to have a freind turn the chair toward the plane, unless you kept the plane in front of you, im sure there is somebody in the community that could put a prototype together and get futaba or spektrum or somebody to make it-there should be like a usb port in a regular Tx and you just plug the optional chair harness into the Tx-that way the Tx would be able to be used regularly without the chair...hmm....thinkin now........
