RE: RC Surfer
Rainer
I was hoping for the same result ,stiffer lid= less leakage
yeahImanaged to shift the servo forward with no problems at all. I just shifted it as far asIcould with the provided cable length.I knocked out theoriginalservo poles out ,rapped my servo in foil,pushedit down into the epoxy putty to make a mould for the servo to sit in. the putty wont stick to the foil so you can pull the servo back out once it drys.Then I screwed a strap down with two screws over the servo to hold it down tight in the mould.Itdoesn'tmove one bit.
That motorIgot looks identical to that one.the problem i had with mine is it had a smaller gap between the engine mount holes, not sure if yours will to tho. I think the standard engine mount is 25mm and my engine mounting holes were 19mm. bummer! might try change the engine mount somehow.
