ORIGINAL: speedracerntrixie
Looks like the SAP 180 is the way I am going. Looks like the rear exauhst will be far easier to set up. I just took a side job putting together a H9 Ultimate in exchange for the engine and pipe so should have the engine in a few weeks. That will give me time to finish the plugs for the canopy and wheel pants, get the wings and stabs cut too.
Do you cut your own foam? What type equipment do you have (CNC or template and gravity driven)?
I need to get some foam cut with a very high taper ratio (root chord to tip chord ratio). PM me please
