RCU Forums - View Single Post - Balsa USA Citabria Pro Build Countdown
Old 11-02-2010 | 03:28 PM
  #56
rye
My Feedback: (10)
Default RE: Balsa USA Citabria Pro Build Countdown
hi just found this on there web page do you think we should lamanate a 1/8 plywood to the front for the diffenerts from 2 or 4 stroke to gas and i contacted jtecrc about a pitt style muffler just send them the size from nose to firewall they have two sizes waiting to here from them ill post it when i get it thanks rye
http://www.jtecrc.com/dlengineswraparound.htm
Installing the DLE-20 on Your Airplane
Note: The DLE-20 must be installed on at least a 6mm [1/4”] firewall.
The fi rewall must be securely glued to the airplane. Use triangle
stock and pin the firewall with hardwood dowels to reinforce the
fi rewall glue joints. Never install the DLE-20 onto a fi rewall thinner
than specifi ed because it may fail due to the power of the engine.
1. Select an engine mount. A two-piece engine mount that does not
interconnect or overlap at the fi rewall is preferred for the DLE-20, like
the Dubro Vibration Reducing Engine Mount 1.20-1.80 (DUBG1307).
2. Before securing the engine mount to the fi rewall, test fi t the engine
onto the mount and place the mount onto the fi rewall. Use this
positioning to create an engine mounting template. Use the template
to drill the mounting holes in the locations on the fi rewall. Note: A
Template for mounting the DUBG1307 is provided on the back of
this manual. Press the blind nuts into the rear of the fi rewall. If you
choose to use regular nuts or lock nuts be sure to place washers
