ORIGINAL: sbtiger
<p class="MsoNormal" style="margin: 0in 0in 0pt">I have a few engines I’ve purchased and I would like to get opinions on which fuel to use for each engine.<span style="mso-spacerun: yes"> </span>Obviously I would like to keep my fuel purchases to only 1 or 2 different fuels; I don’t want to lug around 4 different gallons of fuel for different engines.<span style="mso-spacerun: yes"> </span>If none of these fuels will work for a particular engine, please recommend one.</p><p class="MsoNormal" style="margin: 0in 0in 0pt"><o
></o
></p><p class="MsoNormal" style="margin: 0in 0in 0pt">Engines I have</p>
<p class="MsoNormal" style="margin: 0in 0in 0pt">Fuels I have</p>
- Wildcat 2&4 Cycle 10% Nitro
- Cool Power Super T
- Cool Power 15% Total Synthetic
- Omega 15% Castor/ Synthetic
<o
></o
>Thanks.
In the 4 strokes I would opt for a fuel with a high percentage or 100% synthetic.. Nitro content >10% would be advised for easier tuning and reliable running.
In th 2 strokes, a fuel with a small percentage of castor or again, 100% high quality synthetic would be beneficial.
Of the fuels you currentlyhave in your stock, I'd opt for the Omega 15% Castor /synthetic.
If you can cope with 2 fuesl, then keep the Coolpower for the 4 strokes and the Omega for the 2strokes. Eitehr one of these will work just fine in your engine. Select the Nitro content for smooth 4 stroke running and be done with it.
What I would keep in stock is a range of plugs..
