RCU Forums - View Single Post - Flying time for Pattern competition
Old 11-03-2010 | 09:37 AM
DaveL322's Avatar
DaveL322
Default RE: Flying time for Pattern competition
Tim,
Another approach -
The reason you are not getting a really specific answer is because there is substantial variability in the answer. You will find guys flying Masters on 10S 5000s that are only using 3000 mah for a flight....and you will find guys routinely exceeding 4000. A lot depends on flying style, how well the airframe is matched to the flying style, and how well matched the motor/prop is for the flying style/plane. You can also find substantial variation (as much as 10%) depending on how the mah are measured.....ie, Eagletree, ICE log, charger, etc.
The majority of 10S pattern stuff is between 75 and 95 amps static on the ground, and depending on motor type (geared inrunner, or direct drive outrunner), and heavily loaded, the peak amps in the air will drop 5 - 15%. Average amp draw from takeoff to landing is typically 25 - 35 amps......so figure about 40% of static peak is what you will see for pattern flying. I've found this 40% number to be generally valid on my smaller 3, 4, and 5s pattern/sport planes when flying pattern. Obviously, most of the pattern stuff is 10S, and for your case, if the drop in cell count is roughly equivalent to reduction in airframe size, mass, drag, then you could expect the 40% number to hold up. My gut feel is that your 6S setup is probably being pushed harder than the average 10S setup in Masters, but you are also looking at flying a shorter sequence (initially at least), so I think you'll be fine for Sportsman, Intermediate, and possibly Advanced.
At 7750 RPM.....consider trying some of the APC glow props....you may find them to be more efficient at the relatively high RPM.
Regards,
