ORIGINAL: Kostas1
ORIGINAL: Hobbsy
That does not appear to be a brand new engine, the nut against the carb body has been wrenched on.
Could you be more specific Hobbsy ?
I didn't get it ....?
Is there a problem with the parts that assemble the NV/carb ?
I also couldn't find the parts i need on HHobby,
but i located them at UK and will order the whole set.
It's truly a shame that HH don't carry such parts....
Here are the parts you need at Horizon
http://www.horizonhobby.com/Products...D=SAI450R3D84A
It has been linked to already for you.
What Hobbsy is talking about is that someone has already put this upgrade kit in your carb. They did it with pliers and ruined everything. It is a given that if they used pliers and left off the ratchet spring, they didn't know what they were doing and didn't install the spray bar correct either? There is a notch in the spray bar outlet that must be aimed towards the engine.
