Hallo Alex !
I'm guessing they are using the standanrd industry isolators,(10x10mm aprox), three are more than enough to hold the nose of a c50 ,using one less makes the mount 25% lighter .Changing thrust in small increments is not a problem as isolators can stretch and compress a bit just adusting your back ring. this is what i do ,make sure your mount has short arms ,the shorter the better.
can u post some pics of current 3point mounts ?
Elias
