RCU Forums - View Single Post - Simple Question....
Old 11-03-2010 | 06:13 PM
Panther G
Default RE: Simple Question....
The ones we use are made up of individual links. Even then we usually have too add adjustable track tensioners  too our tanks as the fit is not always acceptable for the model they are used on. Improper tension can cause tracks coming off or worse breakage of the track links or suspension parts them selves. You should always design in a way to adjust the tension of tracks.
