Kevin,
what computer and OS are you running? You are control-clicking on the link and not on some other area of the page right?
You know what, I bet it's your browser. Are you using Safari? If so, try Firefox. It should sort things out.
Frankly simply clicking on it should open it up in your browser. Also, make sure you have Acrobat installed on your system and make sure that Acrobat is the default for opening PDF files (rather than Preview I think it's called).
You need to be able to open attachments if you're going to be navigating this forum!
David.
