RE: OS GPEGASUS 320 GAS CONVERTION
Yah Im am thinkin in it it, i think os easy use 2 twin ignitions I need to fit 2 sensosr oposite 180ยบ If I use one ignition with distribuitor will operate it at very high frecuence, 4 times more faster than in a single enginefor example if I run the engine at 3600 rpom a single engine ignition will operate at 60hz but for the 4 cylinder will operate at 240 hz (switching )
now I have removed the main gar of the starter was very hard to began the convertion I damage the starter gear but I will not use it again
