RE: Nitro engine cleaning
do not use soap and water. take the engine out. take the engine apart if there is a lot of fuel residue you cam clean it with wd-40 then soak it in denatured alchol and use a old tooth brush to scrub it when it is clean use after run oil and put it back together.
