RCU Forums - View Single Post - Ballast Placement CG Caculation
Old 11-04-2010 | 10:36 AM
da Rock
Default RE: Ballast Placement CG Caculation
ORIGINAL: Tall Paul
From the other thread on this:
It's a simple balance equation. Weight of one thing times distance plus weight of another times distance divided by all up weight gives the location of the balance point. Convention has weights forward of the reference as positive, behind it negative.
Typically for aircraft the datum point is ahead of the nose, this keeps all sign convention simple.
If I were to move the elevator servo back on my FlatFlier AD-5W, the c.g. change would be like this...
Just where it comes out with finger balancing...
In your diagram, it looks like your computation only considers the addition of another servo at the tail, not the movement of the servo from around the 17.6 location.
Wouldn't you need to include a - (1x17.6) in the equation?
EDIT: OK, I just noticed the " - 16.52"
I assume that's the servo being removed from it's location which just happens to be on the CG.
