RCU Forums - View Single Post - OS GPEGASUS 320 GAS CONVERTION
Old 11-04-2010 | 11:24 AM
Maximiliano Galvez's Avatar
Maximiliano Galvez
Default RE: OS GPEGASUS 320 GAS CONVERTION
yes 2 ignitions current draw double but I make this consideration
each turn of engine I mean each 360ยบ each ignition will operate oine time
with a single ignition with a distribuitor the ignition will operate 4 times each turn almost the same current
the other problem I see is the avance, adjust it will be diferent because ignition (single) will work undertanding the engine is runing 4 times faster than the really is doing I mean in 1000 rpm ignition will work as if it be in 4000
And in 6000 ignition will be in 24,000 I tested Rcel Ignitions at no more 16,000 over 16,000 sont works well it began to be hto much high switchin frecuence
regards
Maximilliano
