RE: Ballast Placement CG Caculation
If the servo isn't located at the CG as a start point then two moments need to be calculated and added for the total change. The first would be the moment of the servo's weight and shift back to teh CG. And then the other shift to the tail. The two would then add up to produce the total moment shift.
