ORIGINAL: sensei
3M 77 spray adhesive is most likely the worst contact cement you could use. The first thing about it is that it will begin to fail in bond with heat, darker colors in the summer sun can generate that kind of heat to the surface. Try 3M 30-NF, you will really like it.
Bob
Like I said works with some things and not with others ..I have never had it fail though......the 30NF also works well
