RE: General port timing guidelines?
The way you first stated your numbers before you edited your message came out to 149 degrees exhaust timing, and 125 degrees intake timing. Not bad, though a touch conservative depending on what rpms you want the engine to run at.
After you edited your message, the numbers come out to 126 degrees intake timing, (believeable) and 190 exhaust timing, (I highly doubt it.) Check your numbers.
AV8TOR
