RE: hyperion 720 AC/DC Settings Help
Thank you for the reply and all of the great info.
Speaking of LVC the mamba max esc manual says to set it at 6 volts for a 2s lipo, does that sound right?
Last I was kind of freaking out, because the battery is a 7.4 volt but when it was done charging it showed 8.2 or 8.4 volts I believe is this normal? I had the charge set to 2s lipo 7.4v 5000mah and charge rate of 2.5amps. So I'm not sure if this is normal or not. The charge did signal when it was finished.
