RCU Forums - View Single Post - Wanting to use gyro on the tail
Old 11-05-2010 | 01:45 AM
nitro wing
Default RE: Wanting to use gyro on the tail
work on your set up and prop, a 35% Cap should be easy to hover without gimmicks...better try another sim, as the modern ones are VERY good and do translate the hovering with ease.. Good luck! You can do it! why 1/4 scale size servos? there are plenty that have a near normal case and deliver the power needed.
