RCU Forums - View Single Post - Saito Rocker Covers Needed?
Old 11-05-2010 | 03:33 AM
DarZeelon's Avatar
DarZeelon
Default RE: Saito Rocker Covers Needed?
TSky,
I believe [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAI5049A]this is the item[/link] that you need. Or you can take [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAI50GK49]the golden ones[/link].
Ask Horizon to make sure.
Redundant items not put on by the manufacturer cost it nothing...
If Saito put rocker covers on this engine; they thought they are necessary, to keep the engine in good shape and your plane cleaner.
You might want the cover bolts too from [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAI5014]this set[/link] and the proper [link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAI5032B]gaskets[/link].
