RCU Forums - View Single Post - Electric comparison chart
Old 11-05-2010 | 09:47 AM
aeajr's Avatar
aeajr
Default RE: Electric comparison chart
ORIGINAL: Gray Beard
I only have the one electric, the new one is built or framed up but all the gear from the first one is going in the new plane so I know no more about electrics then I did when I built the first one. I went over to watt flyers and read the above post then got on the beginners forum for more info, super bunch of people and I learned enough to get me going. To date I have never seen a chart for complete cross over. I have seen some over the years but nothing complete. Some of the motor manufactures have cross over charts but you have to search them out. Joining the watt flyer forum is the best way I found to locate information and ask questions. I still don't understand much but my plane sure flew good and had way more power then I thought it was going to have. I like electric but it just isn't something I would do 100%, it lacks that wonderful noise of a real engine but I sure like the no clean up and instant starting and flying!!!
You really need to change your mind set.
With dozens of glow and gas engines in each category, each with slevedifferences, bearings, different types of carbs and tuned or untuned mufflers using different mixes of fuels,and hundreds of electric motors withdfferent kV and watt ratings and cansizes and inrunner and out runner and brushed andbrushless,and more coming out each day, Iwould expect there will never be a cross over chart except within a given brand. So you can pick a brand of electric motor, such as Hacker or Electrifly, and stay with their cross over charts or abandon this "what is the equivalent of a .40" mind set and just size you electric systems as electric systems.
As covered in the e-book there are "calculators" that tell you exactly what electric set-up you should use."What electric system would I use for a 7 pound plane with a 55 inch wing span for pattern flying?"Using the calculators that is EASYto answer.
Now you have total freedom to use any brand products you like. That is where the calculators come in handy. For about $35 you get a tool that will tell you the specs you need and perhaps even the exact make and models of electric components to buy. And there are free tools, like WebOcalc, but they are not as comprehensive and assume you understand more and can play around with stuff. I use WebOCalc for estimating the specs of the power system I want, but Ispeak electric.
Otherwise you are working in, "how many horse power outboard motor do I need to replace 500 square feet of sail on a single masted day sailor in a 7 mph breeze on a 20 degree tack?" You can probably answer the question, ... buy why approach it like that. Just go the motor people and say, "what motor would Ineed to drive my 19 footO'day sailer at 10 mph?" That is a lot easier and makes a lot more sense.
But your smileage will vary.
