RE: P200SX vs MAMMOTH THRUST TESTS
The idea of the Merlin/Rhino video is that figures (40.45lbs) can be higher or lower, it is all down to ambient temperature at the time, also rpm and accuracy of the rig. Although in this particular case the temp at the time of running was a little lower than a standard ISO day, but not much, on an 86deg day @ sea level it would be down to around 38lbs.
Rob.
[quote]ORIGINAL: bevar
I would like to see that test done at Kentucky in July. The numbers are probably higher because of the cold OAT at the time of the Merlin test.
Beave
[quote]ORIGINAL: basimpsn
Thats almost 40lbs WOW. What was the max RPM. Thats werid I never seen any (Rhino 170) type engine test run video?.
My opinion
