RCU Forums - View Single Post - Liquid Sheeting
Old 11-06-2010 | 06:26 AM
da Rock
Default RE: Liquid Sheeting
Interesting information about the product:
Description:
Liquid Sheeting is a coating that can be applied to foam and balsa sheeted model surfaces.
It is brushed on with a foam brush, and leaves a glossy, smooth, shell finish.
Cures in 1 hour to an almond color and can be painted with most paints and spray cans.
Eliminates sanding.
Working life is approx 30 minutes. But if kept sealed after mixing working time can be several hours.
Must be used at temperatures between 70 and 80 degrees and humidity above 35% for best results.
Storage life is about 6 months at normal room temperature.
Weight:
A thin coat of LS-2 is approx 0.1 oz/sq. ft.
Finished weight will depend on thickness and number of coats applied
The above info is a guide only and results may vary dependant on application.
