RE: How to convert an ATX power supply to rc use
I am putting together a power supply from an Ultra X-Connect 500W unit. Pt #X-ULT500P.
I can't get it to power up. I have a red ,and black wire hooked together through a 10 watt 10 ohm sandbar, and also tried a 10 watt 1 ohm sandbar.
There is no brown sense wire in this power supply. The sense wire is usually connected at the #11 position in the 20 pin connector. The #11 and #12 wires are Red.
Any ideas?
Thanks in advance,
Greg
