RE: CD ScaleDesigns Albatros CI build
I've also used the same trick: Flat black then rub on graphite. The problem is that using a fuel-proof finish pretty much destroys the fine effect. [/quote]
However I am quite satisfied of the result..........even on the Lewis for the Strutter
