RCU Forums - View Single Post - Good hex driver set
Old 11-07-2010 | 11:46 AM
Mk23socom
My Feedback: (7)
Default RE: Good hex driver set
Where the difference lies between a hex driver and a ball driver is that the section of a ball driver that engages the socket head is ball shaped and can allow you to still turn the screw while the driver is at an angle. A place that Ifrequently use ball drivers where a regular hex wrench would be difficult or impossible to use is on the motormount screws on the exhaust side of the engine where the only way to engage the screw is at an angle. Ihave both the Metric and Standard sets of the Dubro ball drivers and I would recommend them for anyones tool box unless they had a taste for fancier equipment. the part numbers for those are as follows;
Metric Ball Driver set- PN-LXE255 $14.49
Standard Ball Driver set- PN-LXE249 $15.79
When Ibought my Nut Drivers, I simply went to my local Home Depot and bought them for about 15 bucks. Iuse aftermarket bolts and nuts so Ionly need Standard sizes. Idont know what you have for hardware stores in India but thats where Igot mine.
Tower appears to have Duratrax nut drivers in a wide variety of sizes.. they appear to be inexpensive..those may be your best bet as far as what Tower has to offer.
