RE: How to convert an ATX power supply to rc use
Sounds like you don't have the right sense wire selected for the load. Or, the bulb is not enough load for your particular PS. You could attach your voltmeter to the outputs and see if the is any voltage during the startup bump. This should indicate that he PS is OK.
