RCU Forums - View Single Post - Robart valve with FESTO fitting
Old 11-07-2010 | 05:06 PM
cmjets's Avatar
cmjets
Default Robart valve with FESTO fitting
Hello:
I install FESTO fitting in Robart valve, because if I use tube FESTO in Robart valve I always have any lost air, the problem is combine both tubes and his attached (unions).
I use M3 metric thread for fit the fitting FESTO for 3mm tube. The robart fitting are only glued. I hope you like.
Best Regards from Spain.
Carlos.
______________________________
http://cmjets.blogspot.com/
