RCU Forums - View Single Post - Cloud Dancer 40 CG??
Old 08-02-2003 | 09:34 AM
flyerdarren's Avatar
flyerdarren
Default Cloud Dancer 40 CG??
I built the cloud dancer .60 ARF and per the instructions, it said to lift the plane on the wing tips at the main spar. There should be a diagram in your instruction book giving a distance in inches for the CG. Just make sure you measure from the tip s of the wing and not towards the fuse since the wings taper.
