ORIGINAL: dash69
Can you adjust the amount of momentum on the DCBU? Mine is using the rx 18 board in a Pz3 with stock radio. Also can I change the stock radio to a Spectrum 5?
The momentum is either on or off. It is just enough to smooth out the speed curve without it being a real driving hazard.
I have a Spektrum 6i and it works fine. I also just set up a cheap Aero sport and it works fine. The DBC supplies power to the reciever so you don't need the receiver battery pack.
