RCU Forums - View Single Post - Flying in strong Winds
Old 11-08-2010 | 05:21 PM
  #44
Luchnia's Avatar
Luchnia
My Feedback: (21)
Default RE: Flying in strong Winds
ORIGINAL: da Rock
ORIGINAL: frogrocket
The Plane don't know it's windy my friend says all the time.<div id=''divCleekiAttrib'' style=''display: none;'' expanded=''0'' activeid=''-1'' menuleft=''0'' menutop=''0'' menuright=''0'' menubottom=''0''> </div>
Very true for steady state winds, but YOU know when gusts blow it around. And turbulence is more often a part of windy days. Of course, the airplane also knows about turbulence and reacts to it as well, usually before you do.
It was really windy here last weekend and I flew and no one else even came out. I flew quite a bit and it was windy enough that you could slow down and just drop the plane straight on the ground to land. I don't enjoy flying as much when it is real windy but it keeps you on top of your game. However, I got dusted a few times by the wind. Mostly landing gear on some weaker planes I have.
Once was pretty bad when I was flying my GP Revolver 70 and had reasonably moderate winds, but strong gusty burst every so often which was the real problem. They were difficult to judge. I came in for a landing and was about five or so feet up when a side gust blasted the plane and it tilted 90 degrees. I was able to almost get it corrected in time but being close to the ground the the wing tip hit. It spun the plane around and I figured it did not hurt it too bad. I was wrong. When it did, the carbon wing tube was so strong that it broke both sides of the fuselage and was about 5 to 6 hours of repair work.
From then on I generally fly my beaters/bashers in the wind because they can take it better.
