RE: Warped wing advice
Cut thru the shear webs and separate the sheeting from the ribs on bottom side where sheeting is near the trailing edge. Pin it all down then re-glue the sheeting (reach with scrap stick as glue applicator or get a syringe w long tip- use Titebond or similar) and install new shear webs. It may still have a little twist due to the sheeting at the leading edge. Good luck. P.S. it's a Hershey Bar wing and would be easy enough to just build another panel(?)
