RE: Craft Air Cowboy Build
slllooooowwwwlllllyyyyy moving along. For the tip blocks I decided to laminate 2 pieces of 1/2" balsa plank together and shape to the profile of the wing again using a template & router. Next I ran it through the table saw with the blade @ somewhere between 41-43*. 1" wide isn't quite thick enough to catch the full radius of the tip though. I should have added a piece of 3/8". I should also mention, it's EXTREMELY important to make use of sacrificial push blocks for this operation. Kind of tough to run a Tx without thumbs!
