RE: Engine thrust angle question
It wouldn't have any effect on CG.....as CG being off will either make your airplane very sensitve especailly in pitch if you're tail heavy, or hard to slow down or not flairring if nose heavy...those tendencys remain constant.....
If the thrust line is off then the airplane will change in the pitch axis with power changes....
