ORIGINAL: jeffie8696
High wing .40 size trainer.
So you think it would cause the plane to want to pitch down under power if it was set higher? Much like increasing the down thrust.
Raising the thrust line vertically by a half inch while not a hugh change will reduce the tendency for the nose to pitch up during throttle up application and therefore will require slightly less down thrust (angled downthrust).
John
